I didn't want to hijack the other thread that's going today about spirovents, but I am having an issue that is related. I actually have a sprirovent in my system, but air bubbles are being "diverted" before they can get to it.
Sorry for the crude drawing, but I'm at my second job and was hoping for some input on this in case there are some parts I can pick up on my way home tonight so I can work on it first thing tomorrow morning.
I bought my boiler with the "near boiler" piping option. The supply comes off the boiler with 2-3 inches of black pipe and enters an inverted T-fitting (supply side of T-Fitting goes straight up). The supply side of the T goes up about 6-8 inches I'd say, and then enters the supply side of another T fitting. One side of this upper T-fitting has a combination temp\pressure gauge on it, and the other side of the T is my pressure relief valve.
Recently, I will sometimes notice a difference between the temperature gauge in this T fitting, and the temperature gauge on the supply side of my loading unit. I haven't figured out the pattern yet, as this happens very erratically. I've recently figured out that if I give the pressure relief valve a little blip when this happens, the temperature on the upper gauge will shoot right up and mirror the temp on my loading unit. I've placed the drain from my pressure relief valve into a container with water, and when this is happening, I can ease the relief trigger up and get some air bubbles in the water.
So, I realize I've got two problems. 1) This setup appears to be making my spirovent which is a bit further down the supply side ineffective. 2) Where is air getting in the system?
So, what can I do about air getting trapped where it is? Is it a bad setup that I have? . I don't know if I should redesign the temp gauge\pressure relief setup or if I should concentrate my efforts on stopping air from getting in (or maybe both)?
On the few times I've had to refill the system, the spirovent really hisses and dumps some air so I know that is working. I'm also going to try and figure out where air is getting in, but it just seems like a bad design for air to be getting stuck where it is...
