That's fairly normal, get the same here. Like jet engine exhaust shooting out the boost holes. There is also a gap between the manifold and the actual body holes, if they are clogged, someone let a crapload of ash build up and neglected it.[/QUOTE]Mine stay pretty clear. I know this because when I run er up really hot flames shoot out of the manifold holes just like secondaries.![]()
[/QUOTE]That's fairly normal, get the same here. Like jet engine exhaust shooting out the boost holes. There is also a gap between the manifold and the actual body holes, if they are clogged, someone let a crapload of ash build up and neglected it.
Is it normal to have a gap or more than an inch above the fire bricks? Did the previous owners replace with shorter bricks?I don't replace them until they crumble/fall apart. A crack is no big deal IMO. Plenty of 'cracks' between each brick placement.
I'll take a picture in the morning when the stove is cool. I'll also measure. Perhaps they put them in sides first and cut the bottom ones to fit? They'd be 1 1/4" short which is about the gap I have.There's no way the gap at the top of my bricks is more than an inch. You could always measure the brick if you were unsure.
It's an acquired skill to cut it. I use a chisel.
I have a PE Super 27 and the bricks need changing. I went to the store in my area that claims to be a PE dealer and they told me they don't stock the PE firebrick set and sold me some "standard" bricks (without any info; I think they're from US Stove Co. but have to confirm, as I will need more and don't want to mix types).There is a gap at the top of the firebricks on all PE products. You can leave the cracked bricks in place, or even swap them some floor bricks. PE uses lightweight pumice bricks, more expensive than the standard ones. I don't see why standards would not work, but if you want to match the OEM then pumice is the ones. Cheaper to find online than from dealer.
Thanks for that -- they certainly look like what I was sold. Can I replace the back and sides and leave the floor alone, do you think? (That's assuming I can get the back and side ones out without removing the floor.)US Stove sells replacement pumice bricks. They're ok to use in this stove. They are grey, rough textured, and light. Is this what they sold you? It's okay to mix some new bricks with old. I just replaced my rear bricks last year with the US Stove pumice bricks. They're doing fine.
Great, thank you! Wow, 16th season! I've been feeling so remiss for letting mine go 10. I'll see if I can get the vertical ones out, and try to load more carefully in future.Yes, no problem. I only replaced the most worn bricks. In our stove's case it is the rear bricks that take the most abuse from splits hitting them on hot reloads. The rest of our firebricks are going on their 16th season.
