Yeah, at the back of the stove it's reading returning air to the convection process. FWIW, you also can cut the probe wire and add on some thermostat wire and run it into the next room or there abouts. I think Harman allows 25 ft or so . Honestly I have not needed to do that. But if you mount it too low that isn't so hot either. Cool air returns along the floor, I've found that 3-4 ft off the floor is a good place behind the stove. There are several of us who do this in the forum, some not so active these days I might add. In fact I believe Tony does the same as I do.
"And incidentally, the stove will only feed at 3.5 when it calls for it, it's not a fixed setting ( I hate getting into this yet again but almost all Harman users end up running their stoves after all is said and done someplace between 3 and 4 or 4.5 nuff said, meanwhile they just deceive themselves into thinking they are saving pellets or some other notion)" .
Actually, you don't have to cut the temp probe wire to run it on a thermostat. I have my P43 on a thermostat so that it keeps a room in the middle of the house a certain temp. If you ever want directions on setting that up, let me know and I'll help as best as I can.
The P61 is run on auto/room temp, using the probe and I have the probe straight out from the side of the stove and about waist high. Of course as long as the probe isn't on a cold wall or floor (like my basement), or a hot chimney (or next to the kitchen stove), you can just adjust the temp dial to get the warmth you want - regardless of whether that is at 60 or 80 to keep the room at 72 (for example). Argh, I've probably muddied the waters right there.
I run both stoves on room temp / auto until the deep freeze arrives in late January/Feb. Then I switch over to stove temp. but htat is a whole different story, and not one you need to worry about right now.
