Issue:
Work boat is often away from source of electricity and engine needs to be warm to start plus live aboard crew needs heat and cooking ability.
Problem;
existing diesel fired boiler consumes 2gallons/hr or about $200/Day.
Proposed solution;
I bought a Glenwood kitchen range.
Coal burner with a gas top for the summer.
Plan;
replace gas range with Glenwood and install Hilkoil to heat water.
Run engine coolant through Hilkoil
Thusly keeping engine hot.
Also run coolant through a 40 gallon Superstor for crew conveince (showers, dishes) .
Knowledge gap:
Gravity circulation.
What are the basics, the parameters, etc.
Engine and stove are at approximately the same height.
I can place the Superstor higher or lower.
I can put the expansion tank much higher if helpful.
Appreciate all input.
Problem;
Proposed solution;
Plan;
Knowledge gap:
![[Hearth.com] Another home brew boiler; gravity circuit. questions [Hearth.com] Another home brew boiler; gravity circuit. questions](https://www.hearth.com/talk/data/attachments/146/146887-5160da8ad4e282b329a891c05cc9decd.jpg?hash=CVQIF-dRd6)
