Just wondering if there's any relationship between say a stovetop temp of 600,and the cat temperature ,is there an ideal range ?are the two temps supposed to be vastly different etc. I'm sure someone knows what i'm asking. Thanks
HotCoals said:Don't worry about it being all the way over...I would worry more about flames licking the cat and sending all that heat up the pipe on 3.
Why do you have it on 3?
Did you just fire the load?
Hass said:HotCoals said:Don't worry about it being all the way over...I would worry more about flames licking the cat and sending all that heat up the pipe on 3.
paint curing, wants a stove temp of 600.
I've only been able to get 525 out of it so far.
Any fear about flames licking the cat damaging the cat? Or is it just wasting the heat?
HotCoals said:I don't really know how your new stove is.
My BKK has a flame shield in front of the cat to help with keeping the flame away from the cat..still,I don't like to see a lot of flame..it can damage it..yes.
I'm sure your cat is red hot now..shut the air part way down but keep some flame and you will hit 600 pretty easy..I do with mine.
I don't have 4 hours on my fans ..never use them at all hardly.Hass said:HotCoals said:I don't really know how your new stove is.
Yeah, it has a flame shield there too, it's a rectangle pieces with holes in it. The cat has been glowing since I closed the bypass 3 hours ago. started glowing almost immediately.
So do you have any fear running your stove on 3 without the fans on? In the case of a power outage or anything? I know the stoves come without fans so I imagine it's entirely safe.
HotCoals said:I'm sure the Chinook must have a by-pass and that you have have it out of by-pass.
EDIT: just seen your post above.
HotCoals said:My feeling on theses cat stoves is that they are the cats butt for maintaining temps in a house for long periods of times.
If someone wants fast hot fires once a night then I think a tube stove is a better choice.
Hass said:HotCoals said:I'm sure the Chinook must have a by-pass and that you have have it out of by-pass.
Thanks for your help by the way...
and sorry for the thread hijack to the OP!
I closed it down a bit to 2.5, the cat probe is pegged over. stove top is at about 550... the living/dining room is 78 with all the windows open in the house and it was 25 out last I checked... I can NOT imagine anyone sane enough to do this in the summer time like some of us here do!
Just kidding, I still would if it would have been ready by then.
HotCoals said:Hass said:HotCoals said:Don't worry about it being all the way over...I would worry more about flames licking the cat and sending all that heat up the pipe on 3.
Like I said..tube stoves are great for heating up a cold house fast..they also do good burning the smoke while the fire is low..producing cleaner air and good heat.Hass said:HotCoals said:My feeling on theses cat stoves is that they are the cats butt for maintaining temps in a house for long periods of times.
I figured since a wood stove will be my primary heat for a few years I'd better do it right. I don't have any other source of heat other than an electric space heater...
tube stoves seem like far too much work to me for varying results when heating an entire house.
jeff_t said:HotCoals said:Hass said:HotCoals said:Don't worry about it being all the way over...I would worry more about flames licking the cat and sending all that heat up the pipe on 3.
I've seen the highest temps by getting the load charred with the stat wide open, then backing it down to a bit under 2 until I lose flames, then opening it back up a bit at a time until I get a small flame. The wood is offgassing quite a bit, and I get flames rolling around at the top of the box, igniting off the cat. Hits 600 pretty quick.
The flame shield offers some protection, like getting a fresh load going. I don't think I would want flames licking up there all the time. But then, I've only been burning it for a week and a half.
Burn away!ohlongarm said:I've been told the cat will take probably more flame than one would ever give it,I've had my cat engaged stovetop 600 to 700 with a full load set on 2.5 for a couple hours to watch the fire. Doesn't seem to bother it,I'll start to worry when the warranty runs out. Then a new cat at 300$ or less doesn't scare me. I'm going to burn the King,I don't believe it's meant to be coddled ,BUT I am a firm advocate of dry wood and I've got plenty so only time will tell if the King can stand up to my burn methods.Interesting responses much appreciated.
