Yesterday I had a strong fire going - great secondary flames out of the air tubes and a stovetop temp. at 600-650*. Primary air shut down gradually to 1/4 open. Outside temp. was in the mid 30's. Wood seasoned - hard wood with moisture around 15% - in sun and wind for approx. one year. Chimney outside clear - no visible smoke - just shimmering heat.
Fire continued to burn undisturbed and hot when, an hour and a half into it, flames off the lower logs that had been feeding the secondaries went out so I lost all flame in the firebox. Stove top temp. was still in the 600's. Chimney began smoking like a smoke dragon - ie. not a clean burn at all.
My limited understanding is that once a high temp. with charred seasoned wood has been established things should remain 'stable' while the fire burns through it's cycle.
This happened in the middle of the day when house temp. was also in the 70's and the insert had had plenty of time to get warmed up too.
I worry about this because I live in an area with burning restrictions in the winter due to pollution...My chimney shouldn't be smoking. I also live next door to a man who works for the EPA. I don't want to smoke my neighbors out. I like, and get along, with them all.
I also want to be able to leave my house to run errands without worrying about what my chimney is doing while I am gone. :-S
