Good morning all. I am looking at options for upgrading the venting on my pellet stove. The stove is a Timber Ridge 55-TRPAH (Englander 25-PAH) installed in a corner operating in the finished 600sqft section of my basement. Open stairway, open floorplan upstairs with another 1,500sqft. I also have the HVAC system setup with a cold air return in the finished basement, pulling the hot air off the ceiling and pushing it around the house. It heats that whole 2,100sqft space to 70*F down to 20*F outside before it needs any help from the propane appliances. Venting is left over from my old stove. It's 3" pipe, 45* right off the stove, then a 90* elbow up, 36" of vertical rise to another 90* elbow out horizontally, with a run of 24" and a downturn termination. I run a separate OAK as well, 2" flex pipe included with the stove that runs a similar path but with gentler bends. I calculate the EVL of my current venting setup to be 16.5', slightly over the maximum recommended EVL of 15' for 3". The stove performs pretty good, but I'm seeking to maximize breathing performance so I can run the feed trim as high as possible without a dirty burn. Presently with a good clean exhaust and stove I can run it about 30-40% of the way up with the air trim maxed out - I'd like to do better and get that fuel trim at the max the stove will deliver, if possible.
So, I have a few options. The cheapest option available is to simply extend my horizontal run another 8 - 10 inches inside the home and eliminate the 45* bend, going right into the 90* up bend off the back of the stove. That should be a net gain of about -2' EVL and get the total system down to a 14.5' EVL. That's still very close to the maximum recommended for 3", and I'm wondering if I should rebuild the whole system with 4" pipe to increase my breathing potential. If I did the same layout as my proposed cheapest option above all in 4" I should think that would provide a much less restrictive exhaust. I also like the option of then doing something like Selkirk Direct Temp that can pull the outside air down the vent pipe, eliminating my separate thimble for the OAK, and providing much better flow than that 2" flex hose I have now. I would think the gains of such a change would help me increase my feed trim some more and squeeze the last 1-2000BTUs out of this stove.
Is there any reason not to use 4" vent piping in this application? I know when sizing a performance exhaust on a car the whole "bigger is better" theory can be taken too far. In that application there is a sweet spot in size for velocity and scavenging. I don't understand biomass burning draft quite as well, but I understand there is a similar principal at work with hot air seeking to rise, even with an exhaust blower doing a lot of the air moving. I appreciate any thoughts you guys have as I work to squeeze every last bit of heat out of this install.
