SpeakEasy said:
Spoon said:
Thanks BB. I finally figured out which one it was hidden in.
You found it????
Did the form have a blank on it for you to use for your stove????
I have been able to find their Form, but their version of it is an early version and it does not have any blanks for the biomass credit. I called HRBlock and they were very little help. They told me to put the cost of my unit in a blank that's labeled for something else. They actually told me that it really didn't matter. If the IRS questioned it, the important thing was that I have the backup documentation to prove that I bought the stove. Can you imagine!
-Speak
It's easy - but you have to look at the instructions for Form 5695. For Form 5695, you enter the information on line 3a. In the H&R Block program, that translates to the "Heat Pump, central air conditioner, or water heater" line.
Right from Form 5695 instructions here
http://www.irs.gov/pub/irs-pdf/f5695.pdf
"Line 3a. Enter the amounts you paid for energy-efficient building
property. Energy-efficient building property is any of the following.
c An electric heat pump water heater that yields an energy factor of at
least 2.0 in the standard Department of Energy test procedure.
c An electric heat pump that has a heating seasonal performance factor
(HSPF) of at least 9, a seasonal energy efficiency rating (SEER) of at
least 15, and an energy efficiency rating (EER) of at least 13.
For property placed in service after February 17, 2009, the property
must achieve the highest efficiency tier established by the Consortium
for Energy Efficiency (CEE) as in effect on January 1, 2009. However, if
you purchased property before June 1, 2009, you can still take the
credit if you relied on the manufacturer's certification issued before
February 18, 2009, that the property met the standards in effect before
February 18, 2009.
c A central air conditioner that achieves the highest efficiency tier that
has been established by the CEE as in effect on January 1, 2006.
must achieve the highest efficiency tier established by the CEE as in
effect on January 1, 2009. However, if you purchased property before
June 1, 2009, you can still take the credit if you relied on the
manufacturer's certification issued before February 18, 2009, that the
property met the standards in effect before February 18, 2009.
c A natural gas, propane, or oil water heater that has an energy factor of
at least 0.80 or a thermal efficiency of at least 90%.
must have an energy factor of at least 0.82 or a thermal efficiency of at
least 90%. However, if you purchased property before June 1, 2009,
you can still take the credit if you relied on the manufacturer's
certification issued before February 18, 2009, that the property met the
c A stove that uses the burning of biomass fuel to heat your home or
heat water for your home that has a thermal efficiency rating of at least
75% as measured by using a lower heating value. Biomass fuel is any
plant-derived fuel available on a renewable or recurring basis, including
agricultural crops and trees, wood and wood waste and residues
(including wood pellets), plants (including aquatic plants), grasses,
residues, and fibers."
