I pulled out the blower and cleaned it just now, and it seems to me that running it without the blower in an extended power outage, might work better than with it installed.  Any real experience out there?
			You would think so, but I was searching for someone with real experience. I guess I could try myself. The blower comes out pretty easy.Anything that doesn't block convection air has to improve the flow. That physics stuff.
![[Hearth.com] Anyone Run a Hampton or Regency Insert With The Blower Removed? [Hearth.com] Anyone Run a Hampton or Regency Insert With The Blower Removed?](/talk/proxy.php?image=http%3A%2F%2Fwww.mckeznak.com%2Fpics%2FStove-Setup.jpg&hash=b2f2cc7305a095e3a7e8a0875c32240b)
	Geez, that must've been a drag.I did it..my house flooded and the stove was underwater and the fan got fried..it started overheating so i took the surround off..then i took my haborfreight floor drying fan...put it right in front of the stove..it worked just as good as the blower.
since we are on the subject of hampton/regency inserts......what type of thermometer do you use i put one above the front glass and it rarely gets above 500....
On the subject of an extented power outages I have a generator, without power I have no water I am on a well. so not worried about the blower.
![[Hearth.com] Anyone Run a Hampton or Regency Insert With The Blower Removed? [Hearth.com] Anyone Run a Hampton or Regency Insert With The Blower Removed?](/talk/proxy.php?image=http%3A%2F%2Fwww.mckeznak.com%2Fpics%2Fstovetemps.png&hash=cfd6a24f9b358680e360d832bfef3cef)
The fan cools off the stove...if i have a good hot fire without the fan on the top of the stove will glow cherry red..turn on the fan and it cools it down a lot..but my chimney is over 30' tall and it is in the center of the house.. so mine burns hot.
Bob,When I burned my I3100L, we had a power outage & I had no generator for back up. The insert cranked for a couple of days & NEVER got cherry red or anything close to that. The room with the insert was taosty & the adjoining rooms were comfortable...Seeing as the blower assembly is not a standard component, but an option on the Regency stoves & inserts, I'd say that it's safe to run without them. The heat doesn't get as far away from the unit before it rises, but it will STILL keep you warm...
