Anyone with bottom feed stoves?
sass_eco65
20
Ontario, Canada
I have been told that bottom feed stoves are prone to burnback? Has anyone ever experienced a problem with this design before?
If you could also give me the vertical rise of your chimney that would be great. I have been told that if you have less than 12' vertical rise that there will be no natural draft and can cause burnback on a bottom feed stove.
Even the fancy Harmans are bottom feed as I've been told. Wondering if there is some sort of safety mechanism on the Harmans that would prevent burnback. Thanks.
I have a bottom feed ESW with 6' of 3" chimney. In 4 years never a hint of burn back.
All harmans are bottom feed. Burnback protection is in the form of a double augur setup and sealed hopper.
Reactions: bogieb
My Harman does not have a double auger setup. Don't think many of them if any do actually.
Ah my mistake. I own a quad so what do I know lol. Topfeedermasterrace.
Englander uses a two auger setup to make a physical break to prevent a burn back. Top auger on timer, the bottom constant feed to pot. Harman uses a shuttle like device to make a break in hopper feed.
Is your install on main floor or basement? Your 6' chimney being total vertical or just outside? I have been told that inside does not count... It's only the vertical rise outside that does.
Main floor. 6' rise inside from clean out tee to 90* and through the wall to an end cap. No vertical rise outside.
My Harman is in the basement with a 6' angled-vertical rise inside. No outside rise.
The only problem I've had with a bottom fed stove was with an Englander that blew the combustion motor. While it was shutting itself down, the auger went in reverse, drawing burning pellets back in (scared the crap out of me when I saw that!). Did not result in a hopper fire though - I'm guessing because of the double auger. That stove was set up with about 1' vertical rise inside, and no rise outside.
I would assume that any stove that doesn't have some sort of safety mechanism will specifically state in the install directions that they can't be vented straight out, and what kind of vertical rise is required.
The Earth stove was a bottom feeder and had a drop cup above the auger that prevented the dreaded burn back.
