A little explanation first..
I live in an old farmhouse (1880) in Maine that was added onto in the early 2000's. When they renovated they installed underfloor radiant heating on the first floor and baseboard on the second floor. In the new areas, the radiant floor heat works great and you can feel the warmth on your feet. In the older part of the house, it does not work great and has trouble keeping up with the thermostat (I have it set at 64 and, when it's cold, is consistently at 61-63.) I think this is due to the radiant tubing being installed below the old subfloor, which has two layers of subfloor and a new hardwood floor that is ~2" of flooring for the heat to work through.
The house is approximately 3,000 s.f. between two stories. We close off two upstairs bedrooms and two downstairs rooms in the winter to allow the wood stove to heat the space we use better.I currently have a Jotul F 600 wood stove that I installed this year that we use to supplement the radiant heat that we keep at 64.
Will all that being said, I am interested in installing a Jotul GF 600 natural gas stove to heat the old part of the house that is currently being inefficiently heated by the underfloor radiant heat. This would be used in conjunction with the wood stove, but would primarily be for use when the wood stove is not in use. My question is, is using a gas stove in this way efficient? My thought is that I would disconnect the radiant heat zone for the old portion of the house.
