Good evening all. I've burned through my first face cord of wood at this time and I've recently discovered something. The amount of ash in the bottom of my stove really has an affect on the amount of air that gets into the box. If I clean it out and get down to <1" or so, I get a ton of air with the air control lever fully closed! If i burn a few days and get around 3"-4" of ash bed built up, I get a lot less air when the air control lever is fully closed - and I can even put the fire right out sometimes, which is bad... and has created a backpuff boom! Not major, just enough to make you pay attention! Right now, I've got about 2" of ash bed, and when the control lever is fully closed, I get some good secondaries and good burn times as well as higher temps.
Has anyone else found that there's a magic amount of ash bed that yields the best burn?
