Had to replace mine this year, e-bay and was 155 for the entire unit, motor, fans housing just plug and play
ylomnstr said:I've got the combustion fan out right now and don't see any crazy clogs in there. If there's not enough air coming in, couldn't that mean that there's a clog somewhere in the damper intake?
heat seeker said:ylomnstr said:I've got the combustion fan out right now and don't see any crazy clogs in there. If there's not enough air coming in, couldn't that mean that there's a clog somewhere in the damper intake?
Yes.The nipple for the vacuum switch (on my Afton) is on the left side, about halfway up, behind everything. So, any restriction on incoming air will hurt your airflow, but the vacuum switch will still be satisfied. Pull the burnpot and look along the large tube where the air comes in - you'll probably need a small mirror. You could try running it without the OAK hose installed to eliminate the OAK. There isn't much to the intake. Maybe some critters built a nest in there. You could try running the exhaust of a vacuum cleaner out the OAK to see if there's airflow. (Assuming you have an OAK, and the damper is open.) You could try running the vacuum's exhaust out the tube behind the burn pot to see if it comes out somewhere. (It should.)
SmokeyTheBear said:Please see https://www.hearth.com/econtent/index.php/forums/viewthread/71282/
The ash is likely in the outgoing portion of the stove, not too far after the heat exchanger, well prior to the combustion blower.
ylomnstr said:SmokeyTheBear said:Please see https://www.hearth.com/econtent/index.php/forums/viewthread/71282/
Thanks for all the advice. I think I'm done for tonight. I found some more ash up on the sides of where the heat tubes are and got rid of that, and hopefully that will help. I don't think it will though. I've stuck stuff in every hole (that's what she said) I could see and vacuumed everything I could get to, and hopefully it will help. If not, I'm at a loss and don't know what to do next.
SmokeyTheBear said:ylomnstr said:SmokeyTheBear said:Please see https://www.hearth.com/econtent/index.php/forums/viewthread/71282/
You can't stick anything into a non existent hole depending upon when your stove was made you may not have easy access to where the ash is, have you used a leaf vacuum on the stove?
burnsy said:Sorry for the late reply on this, ylomnstr. I did finally figure out what was causing the bad burns. It was not the combustion fan so I now have an extra one for future use. There was ash build up in an area I was not aware of. Try this... remove the plate behind the ash bin.....there are two screws. This compartment leads to the combustion fan and exhaust chamber. Vacuum this area out. At the top right after the opening there is an area I did not realize was there but I discovered it is where the exhaust comes from. Clean out this area with a brush and vacuum. Hopefully that'll do it.
Good luck. Burnsy
