First time poster, long time lurker. I drew on these forums heavily when it came time to pick and install a setup last autumn.
I have an 2020 Ashford 20.2, with 8 feet of double wall, and 10 ft of Excel chimney on top of that. Flue temp thermometer 18" above the stove. No OAK. I burn mostly beetle kill spruce. I don't have a moisture meter but most everything I cut is long dead dried standing dead. I live in a part of the Yukon with a climate similar to Fairbanks (ie -40 right now)
The stove has always performed well, until last week when I came home from being out of town for a week, and noticed that at full open on the thermostat, I wasn't getting the fire intensity I was used to. At full open, bypass open and a full load of wood, flue temps would top around 700 and it didn't have the characteristic 'roar' of a new fire. Ever since, I've noticed my thermostat is behaving erratically. I feel like I can't turn the stove down as much as I used to (there's flame at the lowest setting).
The kicker for me was last night, when I reloaded, the flue temps rocketed up. With the bypass open, I started turning the thermostat down at 800 degrees, but temps climbed all the way to 1200 before coming back down. Then when I turned the thermostat down, it rotated past the 12o clock position and over to about 7 o clock. So high on the thermostat is now 6 o clock, and low is rotated all the way around at 7 o clock. It hits a stop at both min. and max. AFAIK it's only ever rotated between 6(high) and 12(low) before last night. The knob is still securely attached and rotating the rod.
Something feels off to me with the thermostat control. I plan to call blaze king tomorrow but given it's -40, I'd love to fire it back up today, although after last nights brief but intense fire, and the inconsistency with thermostat settings I'm feeling tentative. Door gasket is tight. Am I missing a variable here? Thoughts?
