Auger motor turns, but no pellets
chevelle383
6
emmett, ID
My auger motor is turning, quickly, but the auger itself does not spin. I shop vac'd the pellets clear and it will turn on its own with a little "Help" but goes back to not turning when you stop. No jams.
It looks like the motor has a transmission, and that seems the problem. As I took the motor off and fired it up. Seems very strong at the gear.
Any tip son what could be the issue, or is a new motor combo the only way to go?
Would you please tell us what pellet stove you have?
It will help us with the diagnosis of your issue...
There may be a set screw or hairpin clip that connects the auger to the gearbox shaft. Can you see the output shaft of the gearbox, to see if it's turning?
Here is a tip Son,
Remove the auger and see how it connects to the auger shaft. It may be disconnected or loose.
Stroker 383 I assume?
