Auger motor
Griny
60
Western WA
Can anyone tell me how many rpm's this one runs? People say that its not that important you may be off a couple rpm but I think it does.
For example if your auger motor is running 1 rpm and you install another one that does 2 rpm you increase your pellet rate by 100%
I know you can lower your pellet rate to put it on the lowest setting but it wouldn't be how it supposed to be.
[Hearth.com] Auger motor
I believe its a 1 rpm. The cross I got was to a C-E-017 1 RPM from a breckwell replacement.
One way to be sure is mark the out put and rig up a lamp cord to it. Plug it in and time it for 1 minute. see how many rev's you get.
If you have over feed issues from the stove. It could be the control panel? I have seen them not properly control the auger motors cycle. Once you hit the on button they just continue to run non stop. I would check that too!
Thanks for the good info.
My auger motor is fine for now but am looking into other options for if this one quits on me and then have to go to the local Lopi dealer and buy there high dollar "LOPI" part which is bs since they banned everything from the innerwebs... and I know for sure they are out there just know where to look!
My auger motor is fine for now but am looking into other options for if this one quits on me........and I know for sure they are out there just know where to look!
The Gleason-Avery brand has gotten very good reviews. Beefier than standard motors, and also much cheaper. Here's the link to their website...you can buy them direct there (you want #A901):
(broken link removed to http://www.gleasonavery.com/catalog/pellet-corn-stove-motors.html)
