Austraflamm integra thermostat?
Thejacksonfamily7
12
Tumwater,Washington
I bought an integra used about 5 years ago. It has the t-stat wires twisted together and has worked flawlessly but never turns off unless it runs out of pellets or I turn it off for cleaning.
My question is I would like to add a thermostat and have read a lot of reviews but none pertain to the integra. I want one with enough swing to not be burning up the new igniter. Doesn't have to be fancy and I don't want wireless.
Thanks for all the input.
I assume there are two screw terminals where the wire is twisted together. As such your stove would require a mechanical thermostat without the need for power (24v). As such any mechanical thermostat will work and some do have a swing setting. I use a somewhat wireless version on my Quad 1200i which also requires a mechanical stat with a swing setting of 2 degrees above and below.
Mine: http://www.skytechpg.com/thermostatic-and-programmable-units/sky-5301/
Something like this would work as well: http://www.homedepot.com/p/Lux-Digi...gclid=CJnesr35j9ICFQdLDQodSmED3w&gclsrc=aw.ds
Reactions: Thejacksonfamily7
Something like this would work as well: http://www.homedepot.com/p/Lux-Digital-Mechanical-Thermostat-with-Light-DMH110-010/204356282?cm_mmc=Shopping|THD|G|0|G-BASE-PLA-D26P-AirCirculation|&gclid=CJnesr35j9ICFQdLDQodSmED3w&gclsrc=aw.ds
It says I need a milivolt thermostat. Has anyone got away with using a 24 volt thermostat?
