I am attempting to determine the normal burn sequence after the 8 minute initial start-up for an Austorflamm Integra insert. Typically, I have a buildup of ash (+ 3/8" thick) in the burn pot after 4 to 6 hours of burn time which completely seals the bottom holes. I have experienced three good burn sequences (in my opinion) where the combustion motor ramps up every 15-20 minutes (estimated) blowing the ash from the burn pot then ramps down. This sequence kept the burn pot clean and prevented the ash from building up in the burn pot, i.e. prevented the bottom burn pot holes from becoming clogged. Note; these sequences occurred when restarting the insert after a 35-40 minute shutdown, but does not always occur with every warm restart.
During typical burn sequences the combustion motor ramping is less frequent and occurs after the ash build up in the burn pot. Once the build up occurs the increased combustion motor speed is not sufficient to evacuate the ash from the burn pot.
Is this an operational issue with the insert, a pellet issue, or other?
Background:
First winter full winter using this insert - came with the house we purchased last year.
Chimney Sweep installed new steel flexible pipe and capped chimney (August 2014).
Fuel source - Tractor Supply Company premium wood pellets.
Typical dial setting is between 10 - 12 (manual dial, no thermostat, no digital display)
Cleaned the intake air sensor in December 2014.
Cleaned the combustion motor blades and installed new gasket.
Cleaned low limit switch. Installed new gasket
Installed new door gasket and adjusted door. (Helped reduce lazy flame that burned to the left)
Installed new lower cast wall gasket.
Installed new auger motor.
Installed new convection fan assembly.
Thoroughly clean the stove every two to three months (when in use).
Background:
