amick780 said:CanadaClinker said:here's a new alternative to installing a service Xfer switch....... not sure what the cost comparison is between this meter base type and the one the electrician has to wire in the basement panel.... looks simple enough....CC http://www.generlink.com/about_generlink.cfm
Looks like a great setup, unfortunately it will not work with generator that are Full panel GFCI (or neutral bonded). It will trip the Ground fault. Too bad, most generators these days are full GFCI.
Amick, you may be able to disconnect the neutral bond on your generator, especially if was marketed to the lite-duty construction industry. Check your manual, some describe the procedure for this. Of course, make sure you understand why they are neutrally bonded or not. Some generators provide stickers that you attach as a warning if you unbond the neutral.
Mike -
