E
elkimmeg
Guest
First I condem one chimney for lacking code requirement of flue separation
Second the state is going to pull the rug out from under me and take away my certification
I loose my election bid for board of health. Only good thing is it hit every fairway tonight averaging 260 yds plus.. If only i could putt better, but not bad second time out 3 over par
Now comes this chimney situation
While I am still an inspector, I have discovered these code deficiencies recently. The said home being build contains 6,700 sq ft, so not the cheapy cape from yesteryear. The inspection is a throat inspection of a fireplace. Sitting on the ground is a pallet of cored masonry 4” blocks. Wondering what they could be used for I soon discovered they were used to form the backing of the firebox and even the spacing to the wood header.
Code requires solid masonry. Not hollow core The guy doing laying the bricks and blocks does not understand English. It is impossible to have a conversation with him.
I asked him For the masonry license required for chimney construction. He no speak English and continues laying hollow blocks I tell him to stop but he continues Finally one of the framers gets his boss on the cell phone. This guy ask me what my problem is he informs he has done thousands of chimneys this way and never had a problem. I tell him there is a problem and I stopped the job for two reasons hollow core blocks and it being done by an unlicensed worker. He informs me I can’t stop the job he has to pay a crew and is on a schedule. I require him to come to the office and present a copy of his masonry license to be copied and placed on file He can’t comply, as he does not have a masonry license. I said what?. He says no one ever asked for one before and did not even know they exist. The law or code requirement was initiated in 1988 He request me to inspect today and that he changed the hollow core blocks with solids This guy must think I fell off the turnip cart as I can tell fresh masonry and older established motar a few days old the top blocks were changed but none of the bottom. Since there were no solid blocks and I had stopped the job then how can he explain additional work or them being solid?
Here is where this is going tomorrow I am bringing a hammer drill and masonry bit and drill the suspected blocks. If I hit hollow masonry the whole chimney is coming down and installed by a licensed mason. Required is a codebook on the job site, there is none. I will not sign off on a sub standard fireplace non-code compliant.
Wondering out loud here, If the state removes me who will replace me? .I wonder how many substandard un safe chimneys are being build every day. Who will stand up for correct practices Craig knows the dangers of substituting hollow core blocks for solid masonry. Life and safety issues should never be compromised. I will be on the phone with the General Contractor first thing tomorrow. I am going to draw the line in the sand. If I have to I will shut down the entire job including police to evict all workers. I am not doing my job if I allow or compromise safety and code. I should be removed
I miss beantown.
