I just went to refill my little Jotul F100. The stove was down to hot coals and the magnetic thermometer on the top rear read 300 degrees. I put in a couple small splits and went to grab a couple more a few feet away from the stove when I heard a clang. I looked back and the baffle, which on the F100 just kind of wedges into place, had fallen off one side, and was at an angle with the right side lying on the splits above the coals, which were now starting to catch fire. With my elbow length welding gloves on, I tried to lift the baffle and put it back into place. I was having some trouble and was nervous as those gloves can only take so much. I thought it might be a lost cause, so I shut the door and turned the damper all the way down. I was about to post here to ask what to do with the hot stove and the baffle halfway on the burning splits, but decided to give it one more try. I got the baffle back into place, and am feeling relieved but still wondering what the best thing to do in a situation like this might be. I must have knocked the baffle at some point with a split and it was probably ready to fall for some time. I'll take more care in general and check it from time to time when the stove isn't hot. If I hadn't been able to get the baffle into place, what would have been the best move? Is shutting the door and turning the damper all the way down, as I had thought to do, the way to go? Could this cause a major problem?
