I'm looking to install sound/vibration proofing to my basement ceiling, any opinions? I know about rock wool but does that really work?
Music studio or dungeon / torture chamber? Just trying to understand what frequencies you're trying to block...
Usually the best system for residential situations like this, assuming you have an extra coupl'a inches of ceiling height to spare, is to install ceiling joists (can be lighter than floor joists for the same span) between and slightly lower than the floor joists. In this way, your ceiling is completely isolated from the floor. Install bat insulation and sheet rock, and voila... sound isolation.Music/TV and woodworking noises (including shouted expletives).
Sounds very pro. Could he eliminate the sound track and instead put Roxul in the joist cavities then screw sheets of micore over them, then sheetrock? Seems like that would be pretty quiet, at least enough to hush the expletives.
I believe acoustic ceiling tiles are frequently made from the same stuff as Micore in a denser form.Cut & stuff drop ceiling tiles up in the cavity. Back in the day, we used thick sound deadening cork board.
Well yes, but air does a pretty good job of transmitting sound too. That's why air sealing is important for noise reduction.Solid materials transmit noise / vibration.
for a thorough job, Joful explained it pretty well. Nothing solid running from noisy area to quiet area. If there is there will be some sound transmitted. May be overkill, just depends on what you're looking to accomplish and how much noise you want to tolerate.
I agree with this as well. Unless you're splitting up occupancies a little noise transfer isn't a big deal. I hate drop ceilings, but I'll never sheetrock another basement. I went through the same thing about 5yrs ago, and now everyone sits around with headphones on their head watching Netflix!If you have the head room you could always insulate whats there now and put in a suspended ceiling with acoustic tiles. I hate suspended ceilings, but they have their place and the basement is one of them. Still have full access to wires and plumbing and they work well with sound since they're hanging on wires.
