Have a problem that I have been dealing with for the past 2 years and it seems to be getting worse not better with the things I have tried. Here is the background of what is happening.
My house is in the lowest part of a coldesac and I have always had water to deal with in my basement year around. My sump pump kicks on about every 3-4 minutes. I have 2 pumps in the crock (one is a back-up in case the main one dies) with a battery back-up system that will run a pump for about 6 hours in case I loose power and I am not home. This has worked for me about 12 years with out really any problems. Two years ago, my battery back-up transfer switch died and the float on my main sump pump got hung up on the side of the crock and the back-up pump didn't kick on and I ended up with 3 inches of water in the basement before I caught the problem.
Now the problem I have that I can't solve. After the flood, which happened in the winter (Feb.), around spring when the rain starts and the snow starts to thaw I have water that starts to come in on my slab on the far wall opposite of the sump pump crock. The sump pump is working fine and taking out water but it is like the water on the far side can't migrate fast enough under the slab to get to the crock. The place it comes in is the first place that water will start to come in the basement if the power is off and I don't have the pumps working.
This is what I have tried so far. Last year I had the one side of my house that is on the lowest side of the property dug up to see what was going on with the drainage tile. After digging we found that there was no drainage tile and the basement wall was not sealed in any way. After putting drainage tile in and sealing the wall and trying to drain the tile to the lowest place possible on my property. Which ended up having a 4 inch drop from foundation footing to a ditch that runs through my property, no other place to go. The run is about 100 feet. The end of the pipe is almost always covered with water in the ditch when we are in the wet time of the year. Which is 10 month out of the year for me. The easement ditch always has water in it year around but does no always cover the end of my pipe. This endeavor did not help with my problem as the following early spring I had the same problem.
The second thing I tried was to put bigger gutters on the house this fall. I did this to make sure all rain water was getting away from the foundation that comes off my roof. All down spouts were replaced and I made sure that the water was getting away. This seems to not have helped either as a couple of days ago when we got a real warm day with plenty of snow melt and some rain the water started creeping in.
