So here we use 2 pellet stoves as the only heat source. It gets real cold up here and power outages are pretty common. Most times just up to a 5 minute interruption but it can go for hours in a bad storm. What I wanted was a real budget conscious battery backup solution. So here is what I built.
I bought a Server Rack Mount APC Smart UPS 1400. The one I got was MODEL 885-7522/2. These models are built to use as long as you can provide power. The cheaper ones have a limited duty cycle. This is a several hundred dollar APC - however I paid $50 on Ebay because they thought it did not work. They didnt know without batteries they wont work!
Now I am in the used car parts business so I have unlimited access to car batteries so that is what I wanted to use. I also have this in an unheated / very airy garage so fumes are not an issue - wouldnt want to have car batteries charging/discharging inside the house.
Anyway I have two car batteries connected to make the 24V the APC needs and it gives around 2 hours for the pellet stoves to run. (Plenty of time to shut them down in cool weather or long enough to drag out the generator in cold weather.) It has worked very well and I have only replaced one battery once at a cost of $0 for me. You will see inline fuses for protection.
Just thought I would pass this along as I refused to pay the $500 the dealer wanted for a backup that would last only about 10 minutes and wont work the igniter... this one will and has a 950W capacity... bigger ones are available but this works fine for my needs.
I cannot get this to allow me to post an image but here is a link to it: http://postimg.org/image/5n7gbwqqz/
