I lost hydro this week for a day. I was pleasantly surprised to see how well my fabricated crude UPS / Battery Backup worked automatically to support my wood stove. It provided power for my automated controller and its corresponding two circulation fans as well as my other automated controller that controls the motorized damper in the sealed air intake duct. This same setup could be used to power other appliances such as a pellet stove.
Here is the schematic diagram of this hand made UPS. You can ignore the battery monitor circuit with LEDs as this a just a feature. You can also ignore the remote inverter power on feature if you have a generic inverter. You can also replace the relay driver electronics with a simply small relay.
The generic power adapter (wall wart) and the battery charger and the small inverter are off the shelf items found in my garage. The Battery is from a mobility scooter rated at 55A/hr where it will support my wood stove for 8.5 hours. You can use any 12V battery and respective charger, and any power inverter that meets your needs. The relays are fairly healthy. The photo is from when I completed the project last year. I tested a large inverter with a remote power on switch as well as a small inverter with a simply power switch.
![[Hearth.com] Battery Backup [Hearth.com] Battery Backup](https://www.hearth.com/talk/data/attachments/344/344225-66ea56949ed677fd05d9dcb38ca22a1f.jpg?hash=pthtqZApcH)
I always figured if I needed to power my wood stove blower fan in an emergency I could use a 12volt to 110 volt power converter hooked to a car battery. Just for kicks I tried it once and it worked. The popularity of portable power stations has increased in the past few years. Its a good idea for every house who has to put up with old man winter have one.
