Beech Dry times..
Garbanzo62
648
Connecticut
Back in July of 2023, a friend of mine dropped off some fresh cut 36" beech logs. I CSS them and had them stacked by August. Normally, I test a few splits from my piles just to be sure, but this stuff is a groan to split by hand and I don't want to fire up the Splitter just to test a few pieces. Anyone have experience with dry times on Beech? I would think the 28 Months would be sufficient. They have been top covered but not in a sunny area.
I would guess they should be Ok. Personally I'd get a large piece or two, warm them up inside for a day and split them to be sure. Otherwise just throw one in with other stuff you know is good and keep an eye on it. I could get fresh beech under 20% uncovered but in a sunny windy location in a year at the old place. Beech is awesome firewood.
Reactions: Burnin Since 1991
2 years on beech in our area is usually ok as long as you didn’t split them into huge “all nighters”. Beech is a great wood because it’s dense so it couldn’t hurt to moisture check a couple of the bigger ones. Is the bark peeling at all? I have had well seasoned beech with bark curling, although that’s not a sure bet.
Does it ring like a baseball bat when it strikes another piece of wood? The more it rings, less it thuds, the better it is.
Burn a few splits. See how it does.
Reactions: Woody Stover
28 months is PLENTY for beech. It's one of my main firewood choices. I burn it within a year of CSS. These are normal size splits, 16 inches long and the stack gets sun.
