Hi everyone!
Thanks to everyone here (and some NFPA and other docs), I'm making progress on my installation. The next consideration:
I need to decide how high my thimble will be (so that I can begin creating that hole through the exterior wall and into the existing chimney and liner). I will use temporary heat shields this year, but ultimately I'll be building a raised hearth, so let's assume a stove connection point of about 36" off the floor.
My understanding is that I should have at least 1/4" of rise per foot of run. Even though we are talking less than 20" here, is there any reason to pitch it more steeply than that?
I have two choices: 1. Go straight up from the stove to within 14" of the ceiling and then run two 45s into the thimble (with the appropriate horizontal pitch); or 2. Run two 45s right from the stove into the thimble (again, pitched upward).
Is one better than the other in terms of draft? Do I want to maximize the vertical pipe from the stove before making the necessary bends? My instinct says to do that in order to get a good draft started.
Any and all thoughts and advice welcome. Thank you!
