Hi All- I'm new to pellet stoves and new to forums so I'm hoping you can give me a hand with some issues I'm experiencing. My wife and I recently bought a cabin that had an already installed US Stove model 6041. The owner was an older gentleman and his wife and they had all purchase, professional installation and repair paperwork with the stove. The owner stated he had "given up" on the stove after only a few months of trying to operate it. The cabin is seasonal and they spend little time there in the winter so there were only a few opportunities to use the stove. It appears in "like new" condition. He had his original order which showed the purchase of 15 bags of pellets of which 6 still remained. The stove is approximately 3 years old. The owner had documentation of the circuit board being replaced, the auger and auger motor being replaced and two agitator motors under warranty. He had two additional auger motors that he purchased outside of warranty and installed himself. The stove was not operational when we purchased the cabin as the agitator motor was burned out once again. He "gave up" on the stove when the last Agitator motor burned out within 15 minutes of installation. He described that the agitator fuse would blow and the motor would smoke almost immediately and burn out the winding. This had happened with the last few motors.
I started by thoroughly cleaning the stove as per the manual and checked the agitator system for binding. There was no binding and the stove was whistle clean. I then visually inspected the wiring routing for any pinching and could not find any. I purchased a new agitator motor and started the stove. It ran near perfectly for about 6 hours before I began having multiple issues. Mostly, the stove would continue to burn slower and slower until the low temp switch was tripped and it shutdown. I could always re-start it, but it would shut down at shorter and shorter intervals. I believe I solved that problem by adjusting the hopper door switch slightly as I believe it may have been sensing the door open when it was closed. When I readjusted the hopper switch, the stove seemed to get an overload of pellets as the burn pot overflowed and pellets began backing up the fill chute. I manually shut the stove off as I feared the fire could potentially ignite the hopper or cause other damage. The stove shut down normally. In hindsight, I believe I did not have the bottom damper open enough for adequate airflow. I was running the stove with new pellets on level 5, had the vent air at 6 and everything else on auto. Once the stove shut down and cooled, I cleaned it thoroughly again and attempted to restart it. During the start-up process, I noticed a flash-bulb type flash through the side grate and smelled a burning. I took the side panel off and the agitator fuse was blown and the agitator motor had burned. I ordered a new motor and replaced the fuse with the proper fuse as per the manual. When it came, I installed the new motor and tried to start the stove again. Almost immediately, the fuse blew again and smoked the new motor. I again replaced the fuse and ordered a new motor, however, I am hesitant to try to start it again in fear of smoking yet another motor (they are not cheap)! I don't want to give up on the stove because it has less than 100 hours of use on it and it seems to be a well built item, however, if I can't get it to run... I may need to move on. Any advice you can give would be fantastic... Thanks in advance...
