Best high temp paint
mark cline
804
Cattaraugus, NY
I will be repainting my old Fisher Grandma Bear after I complete the secondary air retro fit. Wanting to get the best results the first time , what is the best high temp paint available?
She has slight surface rust from sitting in the loft of the barn for 2 years , so a light sanding with 200 grit may be all it needs.
My intentions for this stove is put it in the basement of my log home. Which will eventually be my brew haus / man cave. The walls are insulated with 3 1/2" of poly ISO inside and 2 1/2" outside of the 8" thick poured concrete foundation. This should heat the 1600 sq ft basement and any residual heat can flow up the stairwell behind the stove to help out the Mansfield upstairs.
Stove Bright.
That is also the original company that supplied Fisher originally. (Forrest)
Satin Black is closest to original if you have a black stove.
Here's a newsletter with some history of the first colors other than black requested by Fisher. They were just down the road from the first large, and Bob's own Fisher fabrication shop.
(broken link removed to http://forrestpaint.com/wp-content/uploads/2013/07/FP-employee-newsletter-July-13.pdf)
I'll have to read up on the colors, maybe even change the color? But what color ?But now is the time to do it.
Color is personal preference. Any high temp paint is OK. Stove Bright holds the color longer without fading. It does smell the worst of any brand, and it's best to sand outside, paint and fire it for final cure outside. Stay away from Stove Black which is more suited for rough cast iron. It also allows water right through and will rust needing to be polished frequently. All iron; cast doors and steel plate was painted on Fisher Stoves.
To allow the stove to heat the upstairs, you need the heated air to rise near the stove, then cool upstairs and drop back down on the other side of basement to be drawn back towards the stove and rise again. (Codes now require a self closing fire damper in the opening between floors). Getting the heat to rise is no problem as long as you have return air. Returning the cooler air back down is much quicker with a fan in the duct (floor opening) allowing the heat to rise much faster, balancing the two levels.
The best balance is multiple vents over stove for rising hot air, and a stairway at opposite end of basement to allow the cooler air that has circulated across the building upstairs to drop down the stairs like a waterfall. The greater temp differential above the stove has no problem rising through the vents, but has less temp differential on the way down, so it needs a much larger area to slowly drop. Since yours sounds backwards, you can see how a small blower helping it back down at the coolest point upstairs will make circulation much better.
Do not use Stove Bright in a confined space. It is one of the last Acetone based paints and that stuff is nasty. Last time I painted a stove indoors with it I was woozy for a week. Never again.
Definitly will do the final firing outside after the secondary retrofit then indoors for the final install.
Thanks Coaly for the paint info. I am looking into the brush on Stove bright , but the color samples for the 2 browns that are available , look gray more than brown.
Most likely will go with he metallic black if I can't get an answer on the browns.
I plan to have a large vent built into the island in the kitchen which is located on the opposite side of the house .It will give me a return air flow to the basement to complete the convective loop.
This is what the metallic brown Stove Bright spray paint looks like.
[Hearth.com] Best high temp paint
That has a nice look to it. Is that the brush on metallic brown?
Anybody have a picture of the goldenfire brown?
If you do decide to go with the metallic black, could you please post a shot similar to what BrotherBart did? And let us know if it's the satin or flat, please (if memory serves me correctly it comes in both, but I have been known to be wrong). I just did my VC Resolute with Rustoleum flat, and I am far from pleased, so I would like a second coat option. The cast iron I sanded down to was so beautiful I really didn't want to cover it up, but the oxygen I exposed it to forced me to use what I had on hand. Also, what are you painting the interior with?
We don't know what year your Grandma is, but the metallic brown wasn't made until after 1980 for the Grandma IV. (with glass)
Early Stove Bright color would have been Satin for Black or Bark Brown. (non-metallic)
Mybooman, here's Stove Bright Metallic Black;
[Hearth.com] Best high temp paint [Hearth.com] Best high temp paint This was not an original color offered and the nickel plated door was not available until 1980 when the doors had an arched top called "Cathedral". This is a custom stove with plated door and draft caps.
[Hearth.com] Best high temp paint Another high def of metallic black. Again, the doors and draft caps were sent out for plating and not original. It gives you an idea of metallic black by Stove Bright.
[Hearth.com] Best high temp paint This is a good example of the Metallic Brown. (Not Honey Glo)
Depending on light, it has a purple hue that is really sharp with brass.
Draft Caps show correct color in this light;
[Hearth.com] Best high temp paint Aluminum cap in front, solid brass 4 in back. They are all original (new) caps that were never put on stoves from fabricator in Colorado. The black in rear is Satin.
Reactions: CleanFire
Stove Black goes grey pretty quickly. It requires an annual reapplication and makes the stove hard to paint at a later date.
Not sure, probably a strong solvent, perhaps multiple times. Stove black is made from waxes and inks I think.
Coaly that is one beauty of a stove! (The black one, Brown isn't so bad either :) What did you use on the interior? More of the same?
Well I got my Stove Bright paint. I pint of metallic black , 1 can spray primer and 1 can paint prep. I'm wondering if 1 pt of met black will be enough ? I plan to prep and paint the Fisher this weekend , let it cure until next weekend then do the curing burn . I'll post some pictures .
Primer? Is it also high heat by Stove Brite? Normally one does not prime a stove for repaint.
Yes it is stove brights high temp primer . Just read that it is used for an exterior application .Oh well , would it not be good to use it on the stove top that has a good amount of surface rust? What could it hurt?
I have never primed a stove for repaint. You should wire brush the rust and use a drill powered wire brush for the tough stuff. Get rid of the surface rust, wipe down with a solvent like alcohol, then paint in a very well ventilated area.
Don; Lots of reasons not to use it on steel plate. #1 is that water and water vapor go through it and will rust through the coating. It is made to polish rough cast iron. It brings out the detail in intricate castings without filling crevasses, but is like smearing shoe polish on a smooth flat surface. Removing stove black is more difficult on cast iron which it is made for. Lacquer thinner works, it appears to take lots off. But if you fire it up, then wipe again, it's almost just as black on the rag ! I've torched the surface, wire wheeled then wiped with thinner, and it still comes up black after warming it up. Cast iron door is worse. Once done with polish, I just keep polish on the door.
Mark; The primer is only for exterior use like pipe, boilers and good for traction equipment. (steam rollers, traction engines, or outdoor stationary engines)
Don't paint over any rust. Wirewheel or sand to bare metal. If pitted, you can let some paint start to solidify in a small container and wipe it on with spackle knife or plastic scraper like filling with body putty or thick primer used in automotive body work. Lightly sand with 220, wipe with mineral spirits before final coat.
1 1/2 to 2 spray cans should give you two coats.
Nothing is done on the inside.
If you paint it outside, let it dry to the touch, you can fire within an hour. Then take inside when cured. You won't have to move it with uncured paint.
Here a Mapa Bear was wire wheeled and painted within a couple hours and fired in the same spot. I delivered it still warm in the back of a Land Rover and let me tell you a LOT of heat radiates off these when put in a truck with you warm ! I didn't have time to let it cool fully - it was a hot ride I'll tell ya.
[Hearth.com] Best high temp paint [Hearth.com] Best high temp paint [Hearth.com] Best high temp paint
Reactions: HammerheadC4
Ok , no primer , I won't be able to get to prepping and painting until next weekend. Thanks again.
I had used stove polish on my Fisher , about 4 years ago . Now I realize why I have so much rust on the top and cast doors. Do you think I can remove the rust on the door with a light sand blasting or just use more stove polish.My paint is the metallic black, so would it be noticeably different in color?
The heat probably has baked off most of the oils and wax by now. Wire brush it down and then wipe it down with a good solvent like acetone (with protection). Then paint.
