Best place to get a carb rebuild kit, Dealer or ???
HDRock
2,240
Grand Blanc, Mi
Dealer , ebay,Bailey's , or other ???
It's for a HUSQVARNA 61 with a tillotson carb
Ok , I am going to add
1. what, where is fastest way to get a kit??
2. I can get an after market new carb for 25-30 bucks, would it be better to rebuild old one ??
Given that rebuild kits are 10 bucks or so I would buy the new carb as long as it is as good as OEM.
I just bought a new carb for my Husqvarna weedeater from the dealer and it was $24.99. I figure my time is worth more than the difference in cost between the two options. If the carb had been $50-60 I might have bought a rebuild kit.
Reactions: TreePointer
+1
Time and effort are worth something to me. The last time I had a carb issue was on a 25 year old White lawnmower. I found that a new OEM carb was <$30 from PartsTree, so I bought it and bolted it on. No tiny screws, rubber gaskets, plugs, etc. to deal with, and I didn't have to buy that new ultrasonic cleaner I keep putting off getting, LOL!
JacksSmallEngines is also a good place to order rebuild kits.
Yeah. Some new carbs are cheaper than a kit and can of carb cleaner. The last two I needed to kit I just replaced.
I can get an after market new carb for 25-30 bucks, would it be better to rebuild old one ??​
Depends on the aftermarket carb. If it's a recognizable brand, then do it. (Zama, Walbro, etc.) If it's a Chinese no-name, then it's a risk. Could go very well or not so.
Well I fixed the screw on the cover that was letting saw dust in, put a gasket on the carb throat ,gave it a shot of carb cleaner and it's running fine now but in last pic I found oil seeping out, is it coming from the bar oil tank ;? First two pics are of all the crap that got in the carb
[Hearth.com] Best place to get a carb rebuild kit, Dealer or ???[Hearth.com] Best place to get a carb rebuild kit, Dealer or ???[Hearth.com] Best place to get a carb rebuild kit, Dealer or ???
Looks like maybe a leakin case gasket? That's not a simple fix. Would involve splitting the crankcase. I'd leave it alone unless it's making a real big mess or the gasket starts to leak air into the crankcase.
I only ran it a couple of min.though
So , unless the other part of the gasket around the crank case is leaking,It's ok to run ??
I will check torque on bolts, screws
+1 on JacksSmallEngines online for carb kits.
I would try some JB Weld on the case leak foist... splitting them is a PITA. I have done some amazing things with chainsaws using Super glue and JB Weld.
I was thinking maybe JB Weld, if I can get it clean enough to stick, might work out
Use something like Xylene to clean it with, or even lacquer thinner to get the paint off. I have used JB on plastic parts, magnesium and aluminum with very good results. That stuff holds up well over time.
