I had cleared some land summer 2009 which resulted in 15 cord of hardwood approx. 15-20 ft. length logs. The excavators created five (5) stacks - each stack is 3 cord. All logs are piled up. I live in the northeast kingdom of Vermont. I'm trying to figure out what I should do to keep these logs from getting punky, spongy or rotten over winter 2010 and spring 2010 and well into 2011. We burn about 3-4 cord per year. The wood could last up to 4 years I'm told if I store the wood properly, but I don't know how to do this and I know for certain I'm not going to be able to get all 15 cord bucked and split and stacked in 2010.
I'm debating whether or not I should cover these massive wood piles with tarps until summer 2010 when I can get to them to START THE PROCESS of bucking and splitting the wood.
Someone told me that if I cover the wood I will create more moisture. I don't understand how that is possible in the winter when the air is so dry? Maybe I should leave them uncovered in the winter then cover them in the spring?
I would like to make a wise decision on how best to keep the wood from rotting so that I could buck and split 3-4 cord each year. I know I won't have the time to buck and split all 15 cord by summer 2010. It will probably take me a few summers to do all the work.
Thank You for any insights you have... Diana
They did put some small poplar trees on the ground first so that the better hardwood would be off the ground. The wood is mostly White Birch, Maple, Ash and some beech with a little White Pine and Poplar.
Especially of you and the splitter! What a cool idea! Well, we still have no one who would re-stack these logs for us onto pallets or other logs so we will loose some of the bottom logs which are mostly poplar and cedar. Your wood is very neatly stacked and the fact that it will last until 2014 is awesome! Very encouraging to me. If we don't get too much snow this winter we will try to buck up the white birch first as you mentioned and we will save the ash for last! Thanks again! Happy Thanksgiving. Diana
