So i noticed something really strange tonight that I haven't seen before, this is the sequence of events.
I had been burning down a heavy load of coals for about 2 hrs, all raked to the front with the bypass closed and stat wide open. The coals were throwing enough heat to keep the cat healthily in the active area, and the stove top was running about 350
Once the coals were burned down ( stove top was 250
ish) enough to get a decent load in i raked them around the floor of the stove and managed a full load of mostly medium splits but there were a good amount of smalls, it was the last batch of a 1/4 cord before moving more wood into the house tomorrow. This load was N/S with a random mix of white oak, maple, bradford pear, cherry, and english walnut(it was diseased and the wood was worthless for furniture).
Closed the door and waited for good flames then closed the bypass, had almost instant light off. I then set the stat to 3 and waited about 3-5 minutes then dialed it back to the "N", lowest silver area of normal which is my normal cruising spot. This is my normal experience with my stove and schedule. I usually see the stove top temp rise slowly with good active cat until 400
, then the flames die down and the cat glows and the stat does its thing........
What i experienced tonight was trippy. There were lazyish blue/red flames dancing around the box, then the flames would go out...... No biggie I thought, the cat is doing its thing. Well i look up to see the cat and.... on just the right 3rd THERE WERE FLAMES COMING FROM BETWEEN THE FLAME SHIELD AND THE CAT
WTF. Yup all the smoke was hitting the hot surface of the cat and igniting in a ball of flame before going through it.
I opened the bypass and shifted the load with a poked and set everything back in, seemed to have stopped the issue but man, should i be worried about flame impingement with that kind of thing happening.
