Brazing
walhondingnashua
708
ohio
I would like to learn to braze. Not something I will do very often but seems like something valuable to know. I don't want to invest much into it. I do not have an act torch set. I have been looking at the benzomatic kit that uses a small mapp and oxygen tank. Seems to be out of stock in a lot of places. I think this will be the right option for me though. Do I need mapp and oxygen? Can I braze with just a blue propane tank?
Might want to start with a muffler mod so seems like something I want to know.
This is more of a "what do I need to get started" question?
Brazing is a lost art and really not great for exhaust repairs as its a little brittle.. Would be better off to buy a cheap wire feed welder
I do have a mig but have no experience welding anything that thin. Is it possible to turn it down enough to weld something as thin as a chainsaw exhaust?
Lp/ propane and oxy can be used for brazing in most cases, there are a lot of types of braze. various temperature range and strength and does depend on the base material that you are working with. Those Mapp gas sets fell out of Favor a few years back. Those little tanks ran out quick. mig, depends on your machine , if you have finitely variable amperage it will work, some units only have 2-4 fixed selections. Cored ( flux inside) wire dosen't work that well, splatters alot kinda a quality issue there.
used a little wire fed welder for years with flux core in it and yes it does splatter and needs a little extra clean up but their is no quality difference in the weld. I know lots of welders that all they use in their service trucks is flux core because out on site they cannot control the wind and it would blow the gas away, my x boss used flux with gas for some reason i would always just weld with the gas off
Reactions: ozarkoak
