Breckwell Big E pressure switch issues
Jaym4nn
10
United states
As the title says I am having the pressure switch shut the stove off 15 minutes into starting the stove. I checked the POF disc and the high temp disc. Both are working. I tested the pressure switch. It is clicking. When I would jump stove worked, but with a lazy sooty flame. So I cleansed the inside of the stove again. Cleaned the pipe going outside. Took off the combustion blower cleaned that. And the same with the convection blower. Tried the stove same thing. I then checked the door glass and ash pan seal. Everything looked okay. I then plugged the air wash on the bottom of the glass, and now the stove works great. Any ideas would be helpful. This stove never had any issues for two years.
Combustion motor may be on its way out. Ash pan and door seals might look ok but are they sealing? Paper test them and see. My latch cam got softend over the years and didn’t draw the door tight.
Did you replace the latch or were you able to tighten it up?
I made a new one.
