Hi all. Floor is going to be done on wednesday then I start building the hearth and air space. I have a few questions that maybe you can point me in the right direction.....
1. building the brick hearth. I've laid brick before (go ahead and laugh) so I'm familiar with doing that but I just can't wrap my head around how to do it on the floor. I"m guessing I will build a frame of sorts, then put a layer of mortar down and sort of lay it like tile? I guess leaving about a 1/2 space beside each brick to fill in with mortar. So will I need to clamp it all together or anything to have a better bonding? I have some strap clamps or whatever they are called that I got for some picture frames so I can clamp it all together for a few days, but I'm not sure if that is the right thing to do. I've searched you tube and didn't really find anything that I thought was useful. Thoughts?
2. The air space. I'm guessing that I will build this one inch air space after I build the hearth and let the bottom open an inch or so (above the hearth) and then the top open at the wall. I was going to build the air space before the hearth, but I think the hearth should come first then I can measure for the air space off of that.
So any thoughts, advice, direction, lemme at it!
thanks
thanks
