So I wanted to run this by some enthusiasts before moving forward to see what info I could glean. I have built myself a double barrel stove with the top barrel functioning as a heat exchanger (2" tubes running through it). I'm on a 65-acre property and opening a brewery this winter in the middle of the pandemic. We have a 30'x60' metal shed with a stone floor next to our small taproom and I would like to remove one of the shed walls and use the barrel stove to heat it up for temporary outdoor drinking space. I plan to run Single Wall Pipe up to a Stovepipe Adapter to the Class A pipe. The Class A pipe will run through the single tin roof layer, with either adjustable flashing OR a high temp rubber boot over the top of it, then covered with a storm collar, and chimney cap. The entire chimney will be about 10-11' in height and will be 2'-3' over the roof peak. The Class A pipe will not have any kind of ceiling support kit other than some aluminum strips bent up and tapped into it and the inside of the roof.
Does this seem sound enough? I know it's not code but we need to take the bite off of our cold weather and get the doors open finally before we can afford to throw any money at our outdoor seating areas. Let me know if anyone has suggestions or specifically had any experience with these High Temp Rubber Boots (which are new to me). Thanks!
