Hi, new here, in north eastern Maryland. My shop is 60x96x16, and I have my eye on an old fuel tank to build a stove out of. Just drove by the tank today so I don't know the exact size. Looks like its about 3' round and 5' long. My first question would be, what is the thinnest metal I can get away with using for a stove? I can't imagine the tank is much thicker then 3/16''.
My next big question is can I make the stove with two chimneys? The reason I want to do this is because (I'm cheap) I already have enough 6'' pipe for 1 chimney, and I am assuming with the size stove I am planning on making I will need at least a 10'' flue. I have plenty of attic space to move the flues apart from each other or just raise one higher then the other and I am already going to run my flue as close to the ridge as possible. I'm wondering, will two flues negatively effect the draft of the stove, especially when the building gets warm and the stove is cut back or not burned as hot? If it makes a difference I was going to put a baffle in the stove so exhaust wouldn't just run straight out.
