Hi
As some have read before I am changing the look of my fireplace before my insert comes. (Oct 13
!!) I am getting stacked stone up to the ceiling and am going to build/ put up a simple box mantel shelf. I don't do too much wood working but this is not rocket science and I know I can do it if I measure 5x and cut once.
Anyway-
To attach it I will use a wooden cleat screwed to the wall/ studs to create a floating shelf.
- For this cleat do I need it to be the same size as the shelf so the shelf is attached from the top and bottom or is just the top ok? For instance if my shelf is in the void measures 6", can I use a 2x4 or does it have to be a 2x6?
Also I am going to stain it to give it a dark look (Like the typical dark furniture you can buy right now), but want the wood grain etc to be nice.
- What kind of wood should I use?
Thanks in advance for any advice.
soon to be a happy burner
!!) I am getting stacked stone up to the ceiling and am going to build/ put up a simple box mantel shelf. I don't do too much wood working but this is not rocket science and I know I can do it if I measure 5x and cut once. Anyway-
