House was built in 1951 with a walk-out basement. The man-door that leads to the outside needs to be moved/replaced, as it is original, starting to rot, and since there is new framing and insulation on the inner basement walls; this requires the door be moved 5 inches inward toward the basement, to be flush with the newly-framed inside walls.
The original jambs look like they were made from 2x10's, and are rabbeted. They are about 9.5 inches wide, to span from the inside block walls to the outer brick face. The jambs are starting to rot at the bottoms.
So now, the total distance to span with the jambs is 9.5 + 5 = 14.5 inches.
There is also a storm door flush to the brick that I want to replace.
Door is 36x80. Door opening 39 11/16 wide and 83 1/2 high.
Would it be best to try to duplicate the original construction, namely to use 2 8x10s, glued screwed side by side and cut to proper width, to span that 14.5 inch distance? That seems an like unwieldy size, and might be difficult to get plumb and level all around? And hard to shim properly?
Or what about just using 2x6's, one on each side of the opening, and fill-in between them with 1x material?
I guess these options though assume the masonry ends are plumb, which I don't know yet. So would it make more sense to use 1x material to attach to the masonry, then 1x material for the jambs, as though this were a door in a non-masonry wall?
Is there an easy solution i'm overlooking?
