I gathered all my build pics and put them together here........
Thought maybe someone would be interested or maybe inspired...
Wow, awesome job Jesse, reminds me a lot of when I built mine. Wish I had taken pics. What size did you build? Looks like the 130? Looks like the air intakes are 3" pipe?
Also, did you fill in around the air intakes where they enter the firebox?
Did you fill the feed door in with refractory also?
Why do you only have 1" plumbing on yours rather than 1 1/4"?
When I set mine in place I put it on a 1/2" steel plate on top of cinder blocks so it sits up about 9" off the floor, makes it a lot easier on the back when I load it with big chunks of wood.
Pat
I would have liked to see your build pics....... would be interesting to see how yours went together. I did model mine after the rough measurements I got from the 130. The intakes are 2" and i filled in around them with high temp. mortar. The door is filled with the same refractory block as the fire box. I ran 1" pex ( so much easier to find, and less expensive) so didnt see the need to go bigger with the in and out on the pressure vessel. My load door is waist high and 16" tall so it works out great for comfort. Thanks for the compliments....... I still have a group of pictures I want to put together on how and why I changed the exposed insulation situation.
Downeast Farmer.....Most of the pretty welds were done by the buddy of mine in the pics......sometimes mine turn out that way, sometimes not...lol
I had a problem with corrosion real bad where they passed thru the insulation and outer skin.............that was my fixWhy the SS sleeves on the supply and return? I've always wondered why Fred didn't use the inner skins and exposed the insulation directly the the fire.
BTW, I like your draft inducer!
TS
I kid you not, that's what he told me. I basically told him he was nuts, and that in my opinion the best way to run them was full out , with storage to MINIMIZE idling. I was having terrible creosote buildup in mine before I added storage, now its not bad, but I still take the back panel off once a winter and clean the vertical tubes. He disagreed but thought storage was OK. I can assure you, burning big wet rounds in these things will result in a completely plugged HX in short order.Building one may be the way to go. I know Fred Seton very well and after being burned by him I did some research on him only to find he is a narcissist.
THERE'S A SUCKER BORN EVERYDAY!
Fred Seton's business includes: wood stoves, wood boilers, heating manifolds, design work, accounting, and much work around his cabin on the river as he spends much of his time in a wheelchair. After months of getting to know Fred while he was vacationing in AZ, he wanted me to learn the manifolds. Now if you know Fred you know he comes across as an old, cripple, harmless man, who is really close to God, and God just wants him to better mankind with his gifts! He said he would invest the money and knowledge and get me started then when I paid him back he would hand it over to me and we would both benefit. I could also help him and his wife at the time, Carol, around the cabin on a river in the mountains. He can handle the designs and carol did the accounting but that is about it. Jimmy(the best welder/worker ever) handles the wood stoves and wood boilers singlehandedly. Jimmy understands and knows the stoves and boilers way better than Fred ever will. He is confined to Fred's design but knows of better ones. Yes I agree the stoves and boilers are great at holding heat and burning hot. I honestly believe the stoves are great although Jimmy has a little better design. There are common maintenance issues with the boilers. When I was up there we spent hundreds on a couple of new thermostats and much more on antifreeze in one explosive incident and another time the draft got stuck open and it blew again. Basically the amount of money we put in the boiler in a month would have paid an entire electric winters electric bill. He had me plant a huge garden that I took care of, I made several upgrades to the cabin. Worked my butt off six days a week for business ownership thinking Fred is a good man and he is looking to better society. I was making good money before I went to work for Fred as a part business owner I was bringing in $3-4K a month and Fred knew this. I left the business with my business partner because Fred convinced me this had way more potential. Everything was going pretty well a couple of months in we were making serious headway. I was learning the business and paying Fred back quickly. He would always ask what I was going to do When I didn't owe him anything and I had all this money? So after 4 months of being up there and 3 months of running the business I had paid Fred back just over $20,000, what he had invested in me, while maintaining all the upkeep on the house. When it came time for me to take over Fred started questioning whether I wanted to do it or if I could do it. I knew what he was getting at so I asked him if after all I have done for him and following through whole heartedly on my end of the deal are you backing out on your word now? He looked me in the eyes and said F!@# You! I'm going back on my word. So I then asked him what we should do with the 10K we had in inventory that when assembled would be around $20-25K? We both knew I had paid him back for all those materials. He said that's mine paid for with my money tracked to my card, get off my property! So I packed up and left. I then started investigating Fred and his work over the years. I talked to someone who had worked for him for an entire year under a very similar agreement. Fred was letting him take over the stoves and boilers. When it came time for Fred to hand it over Fred pulled the same exact move on him. Larry was using his own credit card to buy all the materials by then so at least he was able to take the materials he paid for. Fred always claims Larry stole $10-40K depending on the day. Yeah that's another Seton Lie. Fred had supposedly sold his boiler company to an engineering firm years ago Bethel Engineering. I found that they made several modifications to the boiler, before realizing its no longer worth it. As you can see from reviews online there doesn't seem to be any professional in the radiant floor industry agreeing with his design work. Fred is a hell of a salesman but ultimately a joke. He stumbled across a couple of youtube videos and figured out how to have someone build it and he will sell it. I didn't have a written contract, no salary/income, nothing to take him to court with. So yeah I was the sucker! I recommend if you are going to do any sort of business with Fred make sure you have a written contract. When buying one of his products make sure you have written proof of his claims and make sure he has insurance to back it.
I don't have any idea if what you say is true. FWIW if you use paragraphs your rant might come off as a little more believable and less like a crazy dude with a personal vendetta. Just saying.
