. The Empyer is supposed to cycle on and off as needed to keep boiler between 170 and 180
. I need to have the oil on automatic standby because if the house temp drops below 71
MIL will be wearing a hat, gloves wrapped in a blanket and on the phone with my wife acting like the world is ending.
.....[/quote]Again, can you tie the aquastat that controls the gold pumps to the oil boilers so that if the gold pumps are on, the oil boiler will not fire?
![[Hearth.com] Can I add storage & would it be worth it? [Hearth.com] Can I add storage & would it be worth it?](/talk/proxy.php?image=http%3A%2F%2Fi3.photobucket.com%2Falbums%2Fy97%2Froundgunner%2FIMAG0355_zps4fdbe379.jpg&hash=485419a6d0b04e179f9cc7cfdbe534f8)
![[Hearth.com] Can I add storage & would it be worth it? [Hearth.com] Can I add storage & would it be worth it?](/talk/proxy.php?image=http%3A%2F%2Fi3.photobucket.com%2Falbums%2Fy97%2Froundgunner%2FIMAG0353_zpsbde48993.jpg&hash=33267da6228476531d7a513b00e511aa)
Or does the wood boiler just take too long to get up to temp once it falls into the 140-150F range?
. If it does it just needs wood and it will come up quickly, I think 1
per miniute or so, after it gets wood. The oil loop on the other hand will go down to 140 pretty quickly if 2 Zones are calling and it takes a while to recover. I'm going to put in a 100 plate HE to replace the 50, if I do a small storage or volume increase that would be the time.That would be fine, as long as there are adequate temperature / pressure relief valves installed. Typical DHW heaters have a 150 psi rating, hydro test to 300. The oil boiler loops should never see > 30 psi due to it's relief valve.
