![[Hearth.com] Can I tile this? Please help! [Hearth.com] Can I tile this? Please help!](https://www.hearth.com/talk/data/attachments/162/162929-f3c53fc4324c2fb2ef48c4d30f88ce5b.jpg?hash=xQ1OZGNZZc)
Welcome to the forum!
Why is there plywood over your chimney? What you really need is a proper wall thimble or you may soon burn your house down. As you said your current setup gets rather hot and the plywood may just ignite at some point if you keep it like it is.
Is that a masonry chimney? Is there a steel liner inside? And what stove do you want to install there?
Yes there are insulated wall thimbles to do what you need.Okay. something isn't right here then. Because I cut a square about 4 inches wider than what it originally was, and if I go any further; I will be cutting into my siding. Is there any possible way to remedy this. Such as double piping, or a heat shield? By the way all I can do at this point is laugh. I'm on par with everything else in the house. The people who lived here before jerry rigged everything from the plumbing to the electric, Good thing my father and uncle are master electricians and plumbers. Now all I need is a master mason! haha
Thanks for all the advise fellas! I have been mulling it over a day or two now. I think I'm going to get a saf-t thimble. (the one that begreen suggested) Put the studs back in where they probably should be, along with insulation, and instead of putting 1/2'' drywall over the studs, I will put 1/2'' cement board and tile it. then final be done with it.
