We've had a pretty good season since the Alderlea T5 was installed in November (thanks again to all who helped with the decision.) But we had a strange and scary problem today after having some work done on the chimney, and haven't been able to figure it out.
Anyone have any thoughts on what might cause the air control to suddenly not be effective in damping the fire down? Here's what happened...
For the past couple weeks, I was having a few concerns about the stove and install: whether we had enough draft, whether the chimney was full of junk already, etc. I was hearing that "raining" sound in the chimney, and it seemed to me we were getting too much smoke in the house when opening the door. So we decided to get another chimney company in to show us how to clean and take a look to see if all was OK.
For context, our set up was that we had 6 inch stove pipe coming straight up from the stove, a 90 degree elbow to exit the outer wall, and then double wall pipe up approximately 30 feet (past the 2nd floor and attic, and above the steeply pitched roof. So, a pretty tall chimney.)
When the guys came Tuesday they ID'd three problems with the install. 1) They said we would get better draft if we have a more gentle slope from the stove to the wall exit, rather than the sharp 90 degree turn. (See picture of how it looks after their mod.) 2) The T-bracket on the outside had the cleaning cap stuck on funny. 3) There was single wall pipe wrapped in insulation going through the exterior wall, rather than double wall. (Ouch -- this last seems to be a serious code violation and dangerous! We're working on getting restitution from the installers for that repair.)
So, they came today to fix these three things. We built a small paper and kindling fire in the stove, they verified that smoke was going up and out the chimney, and left. Five minutes later, we had added a couple of very small logs, no where near filling up the stove, and the room started filling with smoke, apparently from the new stove pipe and silicone offgassing. This was way more smoke than the offgassing when we first installed the stove.
We tried to cool down the fire by shutting down the air control. The fire didn't go down. We watched, and it kept blazing. The stove pipe appeared to get very hot, and the wall behind it got hot. We called the guys to come back, used the fire extinguisher on it, and tried but couldn't figure it out. They decided the wanted to come back Saturday to replace the length of double wall pipe that had a slight bend in the mouth, which he had sealed with silicone. But he said this was unlikely to be the problem, because it would have been hot inside the wall if heat were escaping there, and it wasn't. It was cool, although the room-side surface of the wall was hot.
They moved the stove a couple of inches back and forth while working on it, but otherwise didn't touch it, so I can't see how the air control mechanism could have been damaged.
The installer's theory: The air control "flap" is a flimsy little piece of metal. The new, straighter chimney caused such an excessive draft that it "sucked" it out of position. He plans to recreate the 90 degree bend chimney when he comes back on Saturday to address this.
My husband's theory: There's some leak in one of the many joins on the pipe between the stove and the wall. Air is being sucked in, creating turbulence, and causing the pipe to become a secondary firebox. (Hence the high heat.) Installer says this is impossible.
Does anyone have any ideas, or thoughts on these theories?
Many thanks! We love the T5 and are anxious to begin running it (safely) again.
on a serious note begreen is correct.
