I totally agree on the works of art opinion, coaly. And yep, some of those bushings are pretty elaborate. Pretty outrageous designs cast into some of those old rads and you're right, having a complete set in any house is worth a lot.
just logged on ,did you ever get those radiators converted?You need to cut and break the old fitting out.I just picked up a couple of old cast iron radiators from a neighbor's "remuddling" project, and I'm trying to figure out how to use the standard connectors that they're plumbed with. In the past, I've simply removed these old brass fittings and installed standard black iron or copper fittings into the standard-thread bushings already in the rad, but since these are in good shape and it would be a lot less work just screwing a fitting into what's already there, I'd like to give that a try.
However, they don't accommodate a standard 3/4-inch fitting. The threads are somewhere between 3/4" and 1". I read somewhere (I think) that I what I need are "angle unions" which, judging by most of the other radiators in my house, are a kind of special street 90. No clue where to score such a piece.
Any thoughts? I plan to put 3/4-inch ball valves on these rads instead of conventional radiator-specific gate valves, so I need to reduce the line to a standard 3/4-inch pipe thread at some point.
I can post pics, but won't unless somebody needs to see precisely what I'm talking about.
These rads would replace HW baseboards in my mom's farmhouse, BTW, which I find to be pretty worthless and ugly, to boot. Nothing like a solid mass of cast iron and hot water on a cold winter morning to warm body and soul, IMO.
I have one of the shutter valves I would like to reuse if I can seal it, the packing seal was almost gone do you think an O ring would work?Here's a few of the adjustible type with shutters inside to balance flow; They come in straight and Tee too. To give you an idea of size, they are sitting on a 10 inch stove lid.
The one on the right has a drain petcock with mount ears.
I have buckets of these things, including brass railing parts. Too cool to scrap ! I bought the lot for Lunkenheimer parts, steam relief valves, whistles, and oilers. It came with a bench type threader, portable pipe vice on a long pipe with adjustable top to take into a basement and tighten against a floor joist llike a post, pipe vices that have a strap affair to prevent marring chrome and brass pipe, and large pipe cutters like a chain wrench with cutter wheels all the way around that cuts well casing and larger pipe very easily. $200 for the entire garage full in the 80's. Most of the stuff was from the 1920's and 30's. I bought it for the stuff from the 1800's ;
.View attachment 68963
Regarding corrosion; I studied it a little in the past.
Dissimilar metals will cause a galvanic cell to form and cause corrosion, but remember that corrosion is almost entirely oxidization; when the oxygen runs out [in a sealed system] the corrosion stops.
There are exceptions; stainless steels will corrode without oxygen, but are happy in the presence of oxygen. aluminum will combine with anything.
I've seen the same thing with ball valves; it could be crevice corrosion on the stainless balls due to the lack of oxygen. When fully open, the ball surfaces are protected, you'll never notice a bit of loss in the bore.
Or it could be turbulence [or erosion] corrosion, caused by high water velocity. I believe this is caused by electrical current being generated by the swirling water in the fitting. It's noisy too.
Coaly, good info on old pipe fittings! It's a constant learning process for me. Valve compound... how come I didn't know that? Good tip.
Here in Europe they've moved to straight threads [terrible to seal] but old fittings and some imported stuff has taper threads. BSP, NPT... it's a mess.
I've managed to collect pipe taps from 1/8" to 1", very handy.
I was able to back the original 1 1/4-inch brass fittings out without too much trouble, and I replaced them with 1 1/4 to 3/4-inch reducers and piped it through the floor with black iron going into copper down below. Carried the thing from NY out to Wisconsin in the truck of the family Jetta. It looks really nice in the kitchen--a lot nicer than that old, crummy hydronic baseboard. I assume once winter rolls around, it will heat the space a lot better, too. I'm color blind, so I bought dark brown spray paint instead of black, and didn't notice until it was dry, but Mom says she likes it better anyway.
I found graphite packing at the local plumbing wholesaler , couple wraps doesn't leak a drop,they also had a sweet copper air extractor works great.The usual packing that one can get locally is some kind of string. It fails totally to stop leaking. I found a Teflon Valve Stem Packing (1/8" dia corded Teflon) that worked well. I had to ask a local plumbing supply to order it for me from http://www.gore.com/en_xx/products/sealants/packing/packing.html
Practice a bit with a brazing rod and torch on old brass fittings. You'll get good enough to melt it on like solder and repair your old fittings. A little hand machining and you're fittings are usually useable.
In the electrical trade we call rope packing monkey $hitI visited most of the suppliers between Danbury, CT and Bridgeport, CT. No one had graphite packing which is why I tried the Teflon. Where did you buy yours?
It was at B.A. Robinson Kamloops B.C. just hanging on the wall with all the tap repair parts Oring , cartridges, washers Etc.If I can find the package I'll let you know the brand and part #.I visited most of the suppliers between Danbury, CT and Bridgeport, CT. No one had graphite packing which is why I tried the Teflon. Where did you buy yours?
IMHO I'd be more worried about water staining a 200 yr old floor than using a modern fitting.I have a cracked brass elbow fitting for a cast iron radiator. It is many years old. I took it to a local supply house to get one like it and found that modern fittings even made by the same mfg have a different flare angle and face-to-face distance. I can either buy a spud wrench and add new fittings or find someone who has the antique style willing to sell me one.
I have tried to keep my 200 yr old house authentic and am reluctant to replace any more than I have to.
Ray
Yes, tradesmen say this and they will understand it.. Just like peckerhead is a motor J-box or duck $hit is duct seal or channel locks are water pump pliers.. need I go on?Do you really expect me to say that when I go shopping?
Here's the answer.
http://www.heatinghelp.com/forum-thread/141537/Angle-Union-for-Cast-Iron-Rad-Connection
I pulled the 1 1/4 inch plugs and will replace them with standard 1 14/ to 3/4 reducer bushings. They weren't hard to get out with a 24-inch pipe wrench. I think I'll plumb the visible parts in black iron and make the copper connections below the floor. It will look better, I think, and provide a bit more stability.
Hi Eric
I was told that a ball valve may erode if its used to regulate flow.Havn't seen one that has eroded.
Just thought i'd mention it.
Thomas
