Castle Serenity -Low temp alarm...pellets stopped feeding
Jake86
Burning Hunk
Oct 8, 2015
183
Plymouth, Massachusetts
Brand new stove...starts an runs for 15 mins. and then stops feeding till fire goes out then 15 mins later Low Temp Alarm. Vacuum switch ok..CS closed on weekends. Exhaust piping just cleaned and new gasket. Any Ideas how to get this thing going?
I would check the proof of fire switch .
If it does not read a temp of 52::C the stove
will close down
Maybe a disconnected wire?
Jump it and start stove if continues to burn and heat replace switch
Note don't run the stove for extended periods with the switch jumped
Reactions: ARC
will close down
I went to the manual (daaah) trouble shooting guide and pushed a button on the proof of fire switch and it's been feeding for the past 2 hours.(knock on wood-my head) Thanks people
Reactions: ARC
Like they say if all else fails read the manual :p
Just for clarification, you pushed a RED button that went click?
if so it was the overheat switch that you reset But as long as the stove
is throwing heat then I am happy for you
