Hi
I have posted a few times in the process of building my new alcove where we previously had a fireplace. I am now almost done with the framing and am framing the ceiling of the alcove, which is also the floor of the attic (not finished but used for storage). There is a possibility that someone will walk above the alcove so I am using heavy gauge 2x6 steel framing, 14 gauge for the tracks and 16 gauge for the joists that span a bit under 4 feet between supports. An engineer said that is fine structurally. So I have two questions. First, I am using metalbestos double wall chimney and the framing is not combustible. What piece do I need to run the chimney into the attic through the metal framing? Secondly, the ceiling is 9 feet up. Will I need something between the steel framing and the plywood attic subfloor? (I was thinking a layer of durock or micore)
Thanks again for all of your guidance,
Rob
Rob
![[Hearth.com] ceiling of alcove [Hearth.com] ceiling of alcove](https://www.hearth.com/talk/data/attachments/227/227380-96b79a4f6542a65b7c234651d392d8f6.jpg?hash=Ryf25eb9e1)
![[Hearth.com] ceiling of alcove [Hearth.com] ceiling of alcove](https://www.hearth.com/talk/data/attachments/296/296907-f604aee3827d32112aa424f3c406d4c4.jpg?hash=OAFJ234Mu9)
![[Hearth.com] ceiling of alcove [Hearth.com] ceiling of alcove](https://www.hearth.com/talk/data/attachments/296/296908-fe43a1ee8257c1ef649407c245e7b557.jpg?hash=eHdZR0n1Vt)
