- Oct 3, 2007
- 1,539
I've never had draft issues even in the coldest weather with my chimney-it has two 90s within the first 6', but then it goes straight up for 21'. However, we'll be residing the house eventually and I'd like to enclose the chimney at the same time. Right now the chimney is lag bolted to the side of the house through the vinyl with 3" of clearance (I used a spacer). Obviously the house will be stripped down to sheathing, but where do I go from there? Do I just build a wooden frame around it with 2" of clearance all around? Should the inside be lined with something non-combustible (cement board, etc...)? The outside will be clad in Hardi-Plank.
