Backpack09 said:4 walls
1 bottom
1 roof
a popdoor
a couple of nest boxes
a night light (to train the dumb birds to go in at night)
a window
a couple of roosts (2x4 on the flat)
lukem said:6 - 4x4 (corners and middle support)
4 - 2x8 (band boards)
1 - 2x6 (ridge beam)
? - 2x4 (rafters, rafter perling, side perling, nest box frames, roosts, etc)
Siding (we used T11)
Flooring (we used solid core doors)
Roofing (we used steel pro-rib)
I'll get you a pic this weekend.
smokinjay said:lukem said:6 - 4x4 (corners and middle support)
Sounds like a brick crap house....lol Love to see the pic's I am shooting for 3-5 hens tops.
(broken link removed to http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370533906687)
lukem said:smokinjay said:lukem said:6 - 4x4 (corners and middle support)
It is a beast. The lumber put the truck on the bump stops and then some. Don't remember the dims, but it was at least 8x12.
Kinda long the lines of this...Small and portable. Be able to move it on top of the garden in the winter.
SmokeyTheBear said:1 unit 1" by 6" by 4' solid pine
1 unit 1" by 6" by 4' v-match pine
1 square singles (three bundles)
Wire, conduit, light receptacle, electrical outlet, the boxes for preceding, a timer with manual stops (allows the use of a florescent lamp the digital ones don't always work).
A three gallon electrical (thermostatically controlled) water fountain (metal if possible)
A multiple pound feeder.
This is called hobby wood (mill ends) by Hancock lumber I got mine for $50 a unit which is close to 920 square feet of facing.
15 2" by 4" by 8'
2 4" by 4" by 12'
Don't forget the window area will need to be faced with hardware cloth with no larger than a 1/2" mesh, chicken wire should not be used except to keep chickens out of an area.
All doors need solid hinges and solid lockable latches.
Make certain the build your run solid and preferably covered.
That should allow you to make a 4' by 8' coop that sits about three feet off of the ground and have plenty left over for another coop, a pile of tomato stakes, many 4' raised planter beds and assorted other stuff.
Frame the coop to resemble a ranch.
It is critical that the coop have a lot of ventilation and at the same time prevent the birds from being in a draft.
billb3 said:Ours were always pretty much sheds but we poured about 1 - 2 inches of concrete on the floor over the plywood or boards. The floors of boards either got thin tarpaper ( the stuff you used to use under wall shingles before tyvek) or just plain newspaper between the boards and concrete.
Chicken sh!t will rot floor boards pretty quick without it.
It means you can't build a cheap bendy floor, but you'll probably do that anyway.
Plus you can wash the floor out pretty quick and easy.
My brother just keeps replacing his top layer of 1/2 inch plywood floor when it gets nasty.
I don't think that's cheaper in the long run, but he'd rather do that.
It'll get torn up shovelling and scraping the manure out if you're not careful.
Backpack09 said:They will eat styrafoam, caulk or anything else that they can peck at. I had a nicely insulated coop at one time... not any more, oh well, they seem to keep warm enough in the winter. My box is 4x6x4tall about 3' off the ground a large swinging door on the back to clean out the coop. 3 nest boxes on the sunny side of the coop. all framed with 2x4s and 3/4" sheething. Roof is shed style 2x4s at 20" o.c. with corrogated plastic roofing. I will try and grab some pictures tonight.
I have 6 birds currently but had 10 last fall.
I would recommend checking out http://www.backyardchickens.com/ and their forum for lots of ideas on coop building and general chicken knowledge.
SmokeyTheBear said:smokinjay,
If you keep the chickens dry and in a draft free coop they can stand a lot of cold. I have two coops, one is double walled the other isn't the double wall was overkill.
Neither are insulated.
Chickens really hate it when the temperature climbs above 70 °F after they have fully feathered out (about 7 weeks of age) in fact the birds can easily over heat and die.
Yes by all means spend a lot of time in the section of BYC that deals with coops and run construction. Pay particular attention to the folks that build fort Knox coop and runs then visit the Predators and Pest section there you'll find out why you pay attention to those folks.
smokinjay said:SmokeyTheBear said:smokinjay,
Yea think I have a pretty good grasp. (For Now lol) I still thinking of double wall with 1/4 inch card board I would think it would help keep it a little cooler? What You think if it to much easy enough to scrap that idea?
SmokeyTheBear said:smokinjay said:SmokeyTheBear said:smokinjay,
Over kill in my estimation.
To provide an example my "raised" ranch coop has a ridge vent that runs the length of the roof that has an equal area to the combined soffit vents on both sides. This provides a lot of airflow and it places the air flow above the heads of the roosting birds (keeps them out of the draft). The coop doesn't get any water in it except what is in their inside waterer. This coop doesn't have a heated waterer (I may change that this fall). There are two doors one for the birds and one along with end boards that I can pull out in order to empty the coops litter for the compost pile or the garden (depends upon the timing).
If you use a deep litter system the litter will actually act as both insulation and provide a spot for the birds to burrow in to stay cool (it will when it is working well produce a bit of heat, this takes time and really deep litter).
smokinjay said:SmokeyTheBear said:smokinjay said:SmokeyTheBear said:smokinjay,
Hows your floor done and what you using for litter?
SmokeyTheBear said:smokinjay said:SmokeyTheBear said:smokinjay said:SmokeyTheBear said:smokinjay,
Litter is pine shavings and the floor is pine in the ranch coop and tile in the other one (because it sits on the ground and the tile prevents entry by rodents).
Keep the litter dry and it doesn't matter what the flooring is.
You can even get the girls to help keep things well aerated and dry by tossing their scratch on the litter, they will then scratch the daylights out of it looking for the scratch.
I currently have 6 hens in the 4 x 8 coop and it worked fine last winter except the waterer needed to be tended to more than a heated larger one would. One gallon unheated plastic waterers tend to freeze and crack. But the birds were quite happy. If things get really cold you can provide a something that reduces the area the birds are in it makes a huddle area. The birds produce quite a bit of heat and will huddle to stay warm. Their feed consumption also goes up in the cold weather.
The larger coop has a 5 gallon metal waterer that sits on a thermostatically controlled heating base, it has never frozen. It would if the temperature got really really cold.
SmokeyTheBear said:Your coop for 15 birds should be larger, I wouldn't go below 5 square feet per bird (the tables say 4 square feet but that depends upon the size of the birds and the amount of access time to the run) you should be looking at at least 10 square feet per bird of run space), it is better to have too much room in both the coop and the run than not enough. When there isn't enough room there will be a lot of feather picking, possibly a bit of cannibalism, and there is no place to escape to if there is a coop bully. If you are also planing on having roosters make it no more than one. Better to wear out the Roo than the hens.
Three nest boxes should suffice and don't be surprised if they fight over the same nest box when it comes time to lay. Even with several open nest boxews it isn't uncommon to find several birds in the same box at the same time and the rest yelling at them to hurry up so they can use the nest. Be certain that the nest boxes are well lined (deep I use pine shavings for that as well).
ETA: I turn the aged litter into vegetables in the garden, be certain it is well aged before doing so.
smokinjay said:SmokeyTheBear said:Your coop for 15 birds should be larger, I wouldn't go below 5 square feet per bird (the tables say 4 square feet but that depends upon the size of the birds and the amount of access time to the run) you should be looking at at least 10 square feet per bird of run space), it is better to have too much room in both the coop and the run than not enough. When there isn't enough room there will be a lot of feather picking, possibly a bit of cannibalism, and there is no place to escape to if there is a coop bully. If you are also planing on having roosters make it no more than one. Better to wear out the Roo than the hens.
15 was a mimium order...The run will be 8x8x8 and also the the area under the coop 4x8x2-1/2. Really wanted 7 and want the coop movable. I have a friend with a large coop that will take any I want to get rid of. Figure I would give them a couple months then break down the flock if need be. Not looking to get a rooster if I dont need one...
4X4X8 is the size I have for 6 full sized and 6 bantams. I had a small short coop that I had to crouch and bend to access. Terrible. My new coop I can walk inside. Love it. I bought a used dog pen and put that up with the coop, though they free range in the yard most of the time. My hens did prefer the old coop for laying because it's darker. They don't lay in any of the nest boxes in the new coop. They either lay on top of a spare bale of shavings, or in a rabbit cage I also have in the dog pen for a mama bantam with little chicks. It's comical to watch my big hens try to squeeze in there. SmokeyTheBear said:smokinjay said:SmokeyTheBear said:Your coop for 15 birds should be larger, I wouldn't go below 5 square feet per bird (the tables say 4 square feet but that depends upon the size of the birds and the amount of access time to the run) you should be looking at at least 10 square feet per bird of run space), it is better to have too much room in both the coop and the run than not enough. When there isn't enough room there will be a lot of feather picking, possibly a bit of cannibalism, and there is no place to escape to if there is a coop bully. If you are also planing on having roosters make it no more than one. Better to wear out the Roo than the hens.
No rooster needed to get eggs. It is just that a rooster helps with other things and since I didn't know your plans I just wanted to warn you about not having too few hens and then seeing the damage a Roo can cause.
