I know this is alot of info, but I trust you guys will give me good advice, which I really need. I had a new Lopi Republic 1750 installed this year. Single story house, double wall pipe going straight up through ceiling, through attic, out through roof.
I burn 99% locust from my property, a couple small pieces of pine just for starting. I have two wood piles, one that is dead fall locust, that has been cut and split for about 18 months. Pretty good wood. The other pile was standing trees that were dropped and cut to rounds about 18 months ago, then split last spring. It's okay, but I'm sure it could sit longer.
I use the dry stuff to start my fires (I have less of it), then throw in the less-dry wood once I have a bed of coals. About 15 minutes after adding the less dry wood, I have good flame, and can close the damper about half way and let it run. I have little or no smoke from the chimney at this point, and I don't have any build up on the glass, so I THINK the wood is fine for burning.
Last week, I noticed I could see there was more build up on the chimney cap than I'd like to see. I'd say 1/8" of black "fuzz". I did not take apart the chimney to look down. I ran a couple wide open fires to try to clean it out.
Last night, did my normal routine, started a fire in the afternoon, ran it until about 9:00, then packed it full, ran it wide open with the door cracked open for about 15 minutes. Closed the door when fully flaming, then pushed the damper in about 3/4 of the way about 20 minutes after that. It burns with a low fire this way, little or no smoke, and will last from about 10:00 PM until about 4 AM, when the fan turns off. By 6:00 AM, there is just a few red coals left.
This morning, started a fire, and let it run for a few minutes with the door cracked open, closed the door, damper wide open, and took a shower. Came out, expecting to go close the damper 1/2 way as normal, but could smell cooking paint, which is weird because the stove has been more than cured. The pipe with blazing hot. There was some wooshing noise from the stove, nothing too loud, and there were a couple sparks coming from the chimney, no flame though. SO, panicked, closed the damper down, noise went away in a couple minutes, sparks went away, and I checked everything, including the chimney in the attic space. I'm going to have the installer come out and check everything and clean the chimney.
Okay, so I'm sure it's all because my wood isn't good enough, but the fact that I don't have any build up on the glass, and it burns without smoke, confuses me. Should I not be dampening it so far down at night, especially with this wood?
Also, with the high efficiency stove, that has a plate in the back, I can't see up the pipe with a mirror, what's the best way to inspect it regularly? It's too tall on the roof to look down. Should I take a section off on the roof, or can I take the plate off inside the stove and then see up it with a mirror?
Thanks in advance
Thanks in advance
