My house was built in the 70's and I have a side by side, ceramic lined exterior wall chimney, one for the wood stove that is in the walk out basement and one for the fireplace upstairs. My stove was Federal Airtight was having some flue problems so I took advantage of the downtime to peek in the chimney and noticed about a 6' vertical crack in the liner. Not a wide crack but a crack none the less. The crack was not thee when I cleaned it in the fall. I could use some suggestions on what my options are.
I would add that the chimney has a heavy cement cap on the top and an angle near the bottom. The dimensions of the ceramic liner are are roughly 12" by 10".
